drodrig
- Mar 28, 2013
- 262
Hi everyone,
Today I come with a very basic question but I've been debating with some colleagues about this and we haven't agreed.
When a screw (or bolt) fixes together two plates that work in tensile mode (forces perpendicular to the screw axis). Is the screw working in shearing or is the contact surface avoiding the sheets to move (because of the screw pushing one to the other)?
Attached a sketch
Let's say we have a M10 screw which is threaded on the lower plate (it could be a bolt with a nut). The upper plate has a 11mm hole.
When tightening the screw the plates get together and the friction doesn't allow the force (F) to move them.
Or is the screw working in pure shear? The threads would leave marks on the hole inner wall.
Is it a mixture of both cases?
cheers,
Attached a sketch
cheers,
