I am a relatively new engineer working for an electrical utility. I am interested in sag and tension calculations for aerial cable designs. I have done extensive research and have found numerous information regarding performing the calculations, e.g catenary eqs, parabolic eqs, weight spans, etc. One concept that is not explained in the material is how does the sag and tension change when weight (in the form of a cable) is added to an existing wire. Assuming a piece of messenger wire is installed between two poles and I wish to lash a cable to the messenger, how much more does the messenger sag and how is it calculated? I had someone in engineering run simulations using Sag10 software but I'm interested in the hand calculations. Since I don't have the program, I am looking to manually calculate a particular "what-if". Thanks in advance.
