Hey everyone, if you look at the image, you'll see two similar designs, the main idea behind these two was how the shaft in the right hand design is cheaper to make since compared to the gear shaft in the left picture a large shoulder was eliminated and replaced by just a washer/spacer which serves the same purpose (acting as a base for the gear, and axially fixing it), which is pretty straightforward.
My question however is how these two designs actually work? The gear obviously supposed to rotate relative to shaft (shaft acting as an axle), now it seems there's a bushing on the ID of the gear which acts as a bearing, but what about the fact that it's sitting tight against the shoulder (or washer in the right hand picture)…wouldn't that create lots of friction and prevent the gear to rotate properly? What am I missing, any ideas?
If the gear thickness is slightly smaller than "shaft head" then after you mount it on to the shaft, there will be some axial play, which means gear is not clamped tight against the shoulder (or washer), so that might allow the gear to rotate easier, but still there will be a lot of contact.
This is not a school problem, just a picture I found in an old design handbook!
Thanks~~
Thanks~~
