Drewsaid
- Jul 5, 2005
- 2
I need to determine the flow rate of air into a tank which is to be pressurised, pushing water out of an inclined pipe. The incoming pressure is 6bar before the regulator, and the desired tank pressure is 12kpa the change in volume of the tank due to the pushing out of water is 5 litres
