KirbyWan
Aerospace
- Apr 18, 2008
- 586
So I'm looking at repairing a small access door using a doubler, but the door is plastic and I was wondering if the pressure from driving or squeezing a rivet might cause the door to crack. The door material is .150 thick epoxy sheet molding compoud per BMS8-327 Type 1 which indicates a design material strength of 30 ksi. The material spec gives a strenght of 35 ksi (Boeing being more conservative of course). Is there a reference I can use to calculate the rivet force on the internal face of its hole from being installed?
I suppose this is not a problem with metal materials becuase they are ductile and expand as needed when the rivet overcomes their yield strength, but on a brittle plastic material one pound of force over F(tu) and *POP* ... toss it in the trash and get a new one. And yes I have thought about a fiberglass layup repair, but it's just not optimal for the location of this crack repair.
Thanks,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Thanks,
-Kirby
Kirby Wilkerson
