How to add rotation in two-dimensional axisymmetric model in abaqus? 1
AMINTOFIGH
14
hi everyone
i saw in paper that finite element analysis of clutch disc(sliding and heat generation) is modeled in two‐dimensional axisymmetric in abaqus.
to do this one of the parts should rotate in around z(since there should be a rotational movement between parts to cause a friction and duo to that heat generation). but i cant find a way to that because there is only three degree of freedom is avaible in load section of abaqus. the pic is uploaded is from those papers.
is there a way to rotate parts around z direction in two‐dimensional axisymmetrics like this?
There is an "Include twist" option when you create or edit an axisymmetric part in A/CAE.
