How to apply Coupling Constrain, and Rotation of 3D Model? 1
bhavbhuti302
24
Hello Abaqus Users,
I am very new to Abaqus, and trying to rotate one gear related to other. When I try using the normal cylindrical constrain, I found that it rotates but it also expands the model. So, is there anyway I can rotate the model and other model rotates with that. Also, I feel that coupling constrain can actually help me, but I don't know how to apply coupling constrain. I tried using the abaqus manual but it's not too clear to me. Can anyone please help me to sort this problem out. I will appreciate if someone can upload very simple file having coupling constrain in it.
Thank you
Bhav
Dear all,
I attached the model in format .inp.
The goal is:
I want to calculate the tangential stress in the contact zone.
The problem is:
Two discs with the same material, The angular velocity of the first disc is 410 rpm and the second is 381 rpm. So i thought that i could do it as a static problem, with time increment 0.0001. is it true?
I tried to do it as, steady state trasport, but the problem is that the Abaqus program don´t permit more than one body revolution. so i can make a model for one disc, how can i make the model for two discs?
Now, if anyone has any idea or he/she did something like that, please i want help.
Thank you
 http://files.engineering.com/getfile.aspx?folder=2880e3b2-36cb-47f8-b219-06be5105447d&file=Rolling.inp
With regards to the static question. I believe that you can do this however the 0.0001 will have to be empirically derived. You will also need to have a much more refined mesh where contact will occur at the end of the analysis. I would have a very coarse mesh where contact will not occur and a refined mesh that gets progressively more refined near the end of the analysis. I hope this helps.
Rob Stupplebeen
Sorry I can't add any suggestions for you at this stage, have you looked up any analytical solutions (i.e. hand calcs) to you problem?
Nelio2005, you are right...I have started the thread, but actually I got some what answer after doing trial and error, I am not too sure that I have got right, although I haven't have dynamic model which I wanted to have that initially, but I am just currently working with statically rotated model.
I have attached file here. may be if someone is interested to see that. But I still be interested if someone comes up with idea that how can I rotate one gear and another gear rotates along with the first one, and get results in dynamic condition.
Dear bhavbhuti302
I was looking your model, but it has a problem, i think..
Because when the disc start to rotate the size of the disc has been changed.
untill now, i don´t have any solution for my problem, any help?
Thank you
hello house
i am having problem with my simulation. i want to reel a pipe around the reel and check for residual twist when i unreel but my step of rotation is not going round. i dont kw how to resolve this. can someone give me any head way thank you.
attached is a copy of my work
 http://files.engineering.com/getfile.aspx?folder=31d10b09-c3e5-45c4-9a0d-74d6c7df5d79&file=projectwork2.cae
