how to avoid popup
DesEngineer4
IN
HI
I am using the below journal to move objects and assembly components to respective layers. And this journal is combined with objects and assembly components.
If a part does not have any assembly components means, it is showing an pop up box that there is no assembly components. Can you help me in avoiding that popup...
Option Strict Off
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Module layermove
Sub Main()
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = s.Parts.Work
Dim displaypart As Part = s.Parts.Display
Dim pointcol As PointCollection = workPart.Points
Dim linecol As LineCollection = workPart.Lines
Dim arccol As ArcCollection = workPart.Arcs
Dim splinecol As SplineCollection = workPart.Splines
Dim sketchcol As SketchCollection = workpart.Sketches
Dim bodycol As BodyCollection = workpart.Bodies
Dim allComp1 As ArrayList = New ArrayList
Dim objArray(0) As DisplayableObject
Dim pointslayer As Integer = 90
Dim linelayer As Integer = 90
Dim arclayer As Integer = 90
Dim coniclayer As Integer = 90
Dim splinelayer As Integer = 90
Dim csyslayer As Integer = 40
Dim daxislayer As Integer = 40
Dim dplanelayer As Integer = 40
Dim bodylayer As Integer = 1
Dim sketchlayer As Integer = 40
If pointcol.ToArray().Length > 0 Then
For Each pt As Point In pointcol
If (pt.Layer >79 or pt.Layer <60)
ufs.Obj.SetLayer(pt.Tag, pointslayer)
End If
Next
End If
If linecol.ToArray().Length > 0 Then
For Each ln As Line In linecol
If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1)
ufs.Obj.SetLayer(ln.Tag, linelayer)
End If
Next
End If
If arccol.ToArray().Length > 0 Then
For Each arc1 As Arc In arccol
If (arc1.Layer >79 or arc1.Layer <60)
ufs.Obj.SetLayer(arc1.Tag, arclayer)
End If
Next
End If
If splinecol.ToArray().Length > 0 Then
For Each sp As Spline In splinecol
If (sp.Layer >79 or sp.Layer <60)
ufs.Obj.SetLayer(sp.Tag, splinelayer)
End If
Next
End If
If bodycol.ToArray().Length > 0 Then
For Each sb As Body In bodycol
If sb.Layer >19 Then
ufs.Obj.SetLayer(sb.Tag,bodylayer)
End If
Next
End If
For Each obj As DisplayableObject In workPart.Datums
If TypeOf obj Is DatumPlane Then
objArray(0) = obj
workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray)
End If
If TypeOf obj Is DatumAxis Then
objArray(0) = obj
workPart.Layers.MoveDisplayableObjects(daxislayer, objArray)
End If
Next
If sketchcol.ToArray().Length > 0 Then
For Each sk As Sketch In sketchcol
If (sk.Layer >39 or sk.Layer <40)
ufs.Obj.SetLayer(sk.Tag, sketchlayer)
End If
Next
End If
Dim coniccol(-1) As Tag
Dim conictype As Integer = 6
Dim conictag As Tag = Tag.Null
Dim count As Integer = 0
ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag)
While conictag <> Tag.Null
ReDim Preserve coniccol(count)
coniccol(count) = conictag
count += 1
End While
If coniccol.Length > 0 Then
For i As Integer = 0 To coniccol.Length - 1
ufs.Obj.SetLayer(coniccol(i), coniclayer)
Next
End If
Dim csyscol(-1) As Tag
Dim csystype As Integer = 45
Dim csystag As NXOpen.Tag = Tag.Null
count = 0
ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag)
While csystag <> Tag.Null
ReDim Preserve csyscol(count)
csyscol(count) = csystag
count += 1
End While
If csyscol.Length > 0 Then
For i As Integer = 0 To csyscol.Length - 1
ufs.Obj.SetLayer(csyscol(i), csyslayer)
Next
End If
If allcomp1.ToArray().Length > 0 Then
Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent
getAllComponents2(root, allComp1)
Dim dispobj As DisplayableObject = Nothing
Dim cnt1 As Integer = allComp1.Count
Dim objectArray1(cnt1 - 1) As DisplayableObject
Dim objlayer As Integer = Nothing
Dim cnt2 As Integer = 0
For i As Integer = 0 To cnt1 - 1
dispobj = DirectCast(allComp1(i), DisplayableObject)
objlayer = dispobj.Layer
If objlayer > 19 Then
ReDim Preserve objectArray1(cnt2)
objectArray1(cnt2) = allComp1(i)
cnt2 += 1
End If
Next
If cnt2 > 0 Then
displaypart.Layers.MoveDisplayableObjects(1, objectArray1)
End If
End If
End Sub
Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList)
Dim child As Component = Nothing
Dim space As String = Nothing
For Each child In comp.GetChildren()
allComp.Add(child)
getAllComponents2(child, allComp)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Thanks & Regards,
Sam
Hi cowski,
I want to merge this code to other journals which i am using..How to do this ?
It is enough to ask "Yes or No" no need to open any listing window..Please give me the code for this, so that i will merge with other journal codes.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
		Dim lw as ListingWindow = theSession.ListingWindow
        Dim theUISession As UI = UI.GetUI
        Dim response As Integer
        Dim answer As String = ""
		lw.Open
        response = theUISession.NXMessageBox.Show("Question", NXMessageBox.DialogType.Question, "Move objects to layer?")
        '1 = Yes
        '2 = No
        If response = 1 Then
			'code to run in response to "yes" answer
            answer = "Yes"
			lw.WriteLine("moving objects from layer X to layer Y...")
        Else
			'code to run in response to "no" answer
            answer = "No"
        End If
		lw.WriteLine("user answered: " & answer)
    End Sub
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
Thanks & Regards,
Sam
Yeah I tried,
But, it is showing an error like "declaration expected".
Thanks & Regards,
Sam
I tried in this way:
'1 = Yes
'2 = No
answer = "Yes"
Else
answer = "No"
End If
Thanks & Regards,
Sam
Is that your entire journal?
If so, at a minimum, you'll need to add the imports statements, the module declaration (and end module), and the Sub Main/End Sub statements.
i.e. take the code from your post of 8 May 13 6:03, and delete the 4 lines that reference the "lw" object.
www.nxjournaling.com
Yeah, it is working now.
But, Journal is running even if we click on answer "no". It should exit or to stop running journal when we click on "no". Please suggest how to proceed that.
Thanks & Regards,
Sam
Code:
answer = "Yes"
Else
answer = "No"
[highlight #FCE94F]Exit Sub[/highlight]
End If
The exit sub statement will exit whatever subroutine it is called from. If you are in Sub Main (as in your example) it will exit the journal entirely.
Hi Cowski,
This is the Entire Code for journal:
after running this code, If we click on undo button, it is not coming to the previous state. Why ?
What changes to be done to avoid it.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Features
Imports NXOpenUI
Module layermove
    Sub Main()
		lw.Open
        '1 = Yes
        '2 = No
            answer = "Yes"
        Else
            answer = "No"
       Exit Sub
       End If
	Dim pointslayer As Integer = 61
        Dim linelayer As Integer = 61
        Dim arclayer As Integer = 61
        Dim coniclayer As Integer = 61
        Dim splinelayer As Integer = 61
        Dim csyslayer As Integer = 100
        Dim sketchlayer As Integer = 20
              End If
	     Next
        End If
                If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1 and (ln.layer >199 or ln.layer <80))
	      End If
            Next
        End If
                If (arc1.Layer >79 or arc1.Layer <60 and (arc1.layer >199 or arc1.layer <80))
              End If
            Next
        End If
                If (sp.Layer >79 or sp.Layer <60 and (sp.layer >199 or sp.layer <80))
               End If
            Next
        End If
		If (sb.Layer >19 and (sb.layer >199 or sb.layer <80)) Then
		End If
	    Next
	End If
                objArray(0) = obj
            End If
                objArray(0) = obj
            End If
        Next
                If ((sk.Layer >39 or sk.Layer <20) and (sk.layer >199 or sk.layer <80))
             End If
		sk.Activate(False)
		sk.UpdateGeometryDisplay()
		sk.Deactivate(False, Sketch.UpdateLevel.SketchOnly)
            Next
        End If
            count += 1
        End While
            Next
        End If
        count = 0
            count += 1
        End While
            Next
        End If
        'move symbolic thread arcs to layer 1
	For each myFeature as Feature in workPart.Features
	    if myFeature.FeatureType = "SYMBOLIC_THREAD" then
	        for each myEnt as arc in myFeature.GetEntities
		    myEnt.Layer = 1
		    myEnt.RedisplayObject
		next
	    end if
	Next
        If Not IsNothing(root) Then
            If (objlayer > 19 and (objlayer >199 or objlayer <80))  Then
                cnt2 += 1
            End If
        Next
        If cnt2 > 0 Then
        End If
     End If
    End Sub
            allComp.Add(child)
        Next
        End Sub
    End Function
End Module
Thanks & Regards,
Sam
If you want to undo the actions of the journal, you will need to set an undo mark at the desired location. Add the following code before your journal starts moving stuff.
Code:
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Move object layers")
Hi cowski,
Can you tell me what type of skills are required for customization of NX.
Thanks & Regards,
Sam
Hi cowski,
This is another issue..
The below journal made by us with many trail and errors, by picking one sample vb program from GTAC Solution centre.
As, I already posted with thread name like "Pick a point"(
As of know this journal is asking to pick a point in the form of dialog box. But, it is not showing any message like pick a point or specify the point.
Another issue is, this dialogue box have two options like ok and cancel. Even if we click on cancel it is importing the label at origin of drawing sheet.
Please correct the journal in the following ways:
1. we need a message in that dialogue box like "specify a point"
2. if we click on the cancel button it should not import the label
3. If the user executed unfortunately again the same journal it should show some message like already exists. This is just to avoid multiple imports.
Code:
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module NXJournal
    Sub Main()
        Dim screenPosition As Point3d
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        '   Menu: File->Import->Part...
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
        Dim importer1 As Importer
        importer1 = workPart.ImportManager.CreatePartImporter()
        Dim partImporter1 As PartImporter = CType(importer1, PartImporter)
        partImporter1.FileName = "D:\Lean\sample.prt"
        partImporter1.Scale = 1.0
        partImporter1.CreateNamedGroup = False
        partImporter1.ImportViews = False
        partImporter1.ImportCamObjects = False
        partImporter1.LayerOption = PartImporter.LayerOptionType.Work
        partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
        Dim element1 As Matrix3x3
        element1.Xx = 1.0
        element1.Xy = 0.0
        element1.Xz = 0.0
        element1.Yx = 0.0
        element1.Yy = 1.0
        element1.Yz = 0.0
        element1.Zx = 0.0
        element1.Zy = 0.0
        element1.Zz = 1.0
        Dim nXMatrix1 As NXMatrix
        nXMatrix1 = workPart.NXMatrices.Create(element1)
        partImporter1.DestinationCoordinateSystem = nXMatrix1
        SelectPoint(screenPosition)
        Dim destinationPoint1 As Point3d = New Point3d(screenPosition.X, screenPosition.Y, screenPosition.Z)
        partImporter1.DestinationPoint = destinationPoint1
        Dim markId2 As Session.UndoMarkId
        markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
        Dim nXObject1 As NXObject
        nXObject1 = partImporter1.Commit()
        theSession.DeleteUndoMark(markId2, Nothing)
        partImporter1.Destroy()
    End Sub
    Function SelectPoint(ByRef screenpos As Point3d) As Selection.Response
        Dim view_tag As NXOpen.Tag
        Dim point(2) As Double
        ufs.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
        Try
            ufs.Ui.SpecifyScreenPosition("Select location for new note", _
                               Nothing, IntPtr.Zero, point, view_tag, response)
        Finally
            ufs.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
        End Try
        If response <> NXOpen.UF.UFConstants.UF_UI_PICK_RESPONSE Then _
                                              Return Selection.Response.Cancel
        screenpos.X = point(0)
        screenpos.Y = point(1)
        screenpos.Z = point(2)
        Dim viewTag As NXOpen.Tag = theSession.Parts.Work.Views.WorkView.Tag
        Dim myColor As UFObj.DispProps
        myColor.color = 186
        ufs.Disp.DisplayTemporaryPoint(viewTag, UFDisp.ViewType.UseCursor, _
                              point, myColor, UFDisp.PolyMarker.Asterisk)
        Return Selection.Response.Ok
    End Function
End Module
Thanks & Regards,
Sam
