I am looking forward to install a laser based measurement system on a milling machine. The purpose of measurement system will be to measure small scale relative movements of machine components or machine bed.
The measurement unit weight is about 0.8 Kg. The unit could be screw mounted on a side wall of the machine (using a 25 cm aluminium arm). When machine in working condition, the side wall of the machine may possess some vibration (I guess very low). Thus I assume it will affect the accuracy of the measurement system.
Any suggestion to address this problem? I will be very thankful. Some approaches could be as follows.
• If I use some rubber dampers between side wall and arm, the unit may lose rigidness/stiffness.
• If I use separate mounting for the unit independent of the machine, it shall not be smart solution. There will also be a need of massive mechanical design.
• One solution may be using acceleration sensors at the other end of the arm to measure and compensate the vibration effects (not sure it could be a potential solution).
Any secession would be very welcoming. Thanks in advance.
simrs
