how to connect 4 wire RTD (PT100) in wheatStone Bridge? 6
ak05
15
i want to connect a 4 wire RTD PT100 in a wheatStone Bridge.
i tried searching on internet but only upto 3 wire configurations in bridge are available or circuits using other ADS IC's are available. but i want to do it in a Bridge Configuration. can any one suggest how i can do it?
hey Scotty , nice link...i read on it.. but in the kelvin Section they have not given about which element is varrying and all , means in case i am connecting a 4 wire RTD in that kelvin section how the circuit will look like? can u please tell me?
the ckt is this :
getfile.aspx
@skottyUk i meant where is the location of the 4 wire RTD in that circuit?
"i meant where is the location of the 4 wire RTD in that circuit?"
Did you not read the Wikipedia article you quoted? You solve the loop equations for wherever you put the RTD.
TTFN
faq731-376
7ofakss
Need help writing a question or understanding a reply? forum1529
@IRstuff
m asking about the position of the RTD in this Configuration. not the wiki one.
see below link
download.aspx
where is the location of the 4 wire RTD?
That circuit would use a 2-wire RTD, and it would not compensate for lead resistance. There is no way to deploy a 4-wire RTD in that circuit. You could make a 2-wire RTD from a 4-wire type if you wanted to. Just be careful to cut one lead off each end, not both leads off the same end. ;-)
"where is the location of the 4 wire RTD?"
You again show a bridge, so again, you put it in and solve the equations. And again, you can only use two leads for the circuit you show.
TTFN
faq731-376
7ofakss
Now you're asking for an IC that can accept 4 wire RTDs.. They're not cheap! I gave you a link to an IC that avoids you needing any other ICs and minimizes the code math.
What class IS this for?
Keith Cress
kcress -
