I am new to NX6, and I created a sheetmetal part file that I now want to create a flat pattern of. I attached a picture of my part to this post.
Problem: I know how to use the Unbend feature to flatten the part out, but next when I click the Flat Pattern button, I'm not sure where I should go from there (I'm not exactly sure what lines in my part I should click for the "additional curves" section in the pop-up wizard, for example. I tried a few times and I get "Unable to create body" errors.
Question: Is this the correct way to get a flat pattern made of this sheetmetal part? If so, can someone explain to me how to use the flat pattern wizard? If I need to clarify anything I will try.
Thank you
Thank you
