How to disconnect/separate specific elements in Abaqus? 2
mdama
Materials
Oct 12, 2018
118
Hello
Is there any way to tell Abaqus to disconnect specific elements connectivity when the stress reaches a value or in a specific time? Suppose two parts are tied together but after a while some elements at the interface get disconnected/separated. (like a rupture phenomenon)
You can use Cohesive Elements or Cohesive Contact to simulate bonds that can fail (based on user defined failure criteria). Search the documentation for "cohesive".
Abaqus provides models for predicting progressive damage and failure.
Typically, you define a damage initiation criterion and evolution law. Once an element loses its load-carrying capacity it is removed from the mesh.
These capabilities are described in detail in the documentation:
Abaqus Analysis Users Guide
Materials​
Progressive damage and failure​
Element deletion can also be controlled using a user subroutine and state variables:
Materials​
Other Material Properties​
User materials​
EDIT: Sorry misread your question. Mustaine's solution is a better approach.
