How to enter surveying lines (bearing, distance) can't seem to make it work like AutoCAD does....
bolt37
I have tried everything I know how to do but Draftsight doesn't seem to allow this input. But the "units" section shows it being available...?
You mean like compass bearing, distance? I didn't know ACAD did that.
Just verified that DS will accept the usual AutoCAD syntax
l
0,0
@2<25
@3<90
... etc.
Where the @n is the distance from the 'current' point,
and <xx is the angle in degrees CCW from a horizontal line going to the right.
Mike Halloran
Pembroke Pines, FL, USA
Mike,
Thanks! I got a few inputs to work, but I need to tinker with it more. I plotted my dads farm property deeds on Acad 2-d years ago, then put a PDF image of topographic USGS map embedded in the file, adjusted the scale of the topo image by comparing a scaled line in Acad, then scooted each property boundary into place. It works great.
But I left that company and there is only Draftsite here so I am learning it....
I will play around more now...:)
Thanks!
Brent
