engtiuser2
- Oct 13, 2015
- 43
I am setting up a torque test to verify an insert nut/joint strength for a steel structure. I am wondering if there is any specification/guideline for how much over torque should be used to take into account for the uncertainties (surface condition, lubrication used, workmenship...etc). As an example, 1/2"-20 bolt calls for 46 ft-lb, I normally would arbitrary add 10% (i.e. 50.6 ft-lb) to account for the uncertainty for the torque test. Any comment on the validity of this?
