I have given the Cv as 0.115 and Cg as 27,000 CFH at full cylinder. This is a fisher control valve. Upstream pressure is 500 psig and relief pressure is 425.7 psig. I am trying to find the maximum flow through the control valve. The flow medium is air with 5% Helium. I have a template to find the maximum flow rate. But i need the Cg as constant. Could you please somebody help me in converting the Cg to constant. Stonecold and other guys explained me but I haven't understand exactly.
Thanks in advance
Thanks in advance
