  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
How to Import An Assembly Step File As A single (Monolithic) NX File
n2design
26
I need the process of importing an assembly step files as a single file into NX part file.
I don't think you can, I think you can flatten the assembly structure as per the attached image by editing the import settings, but then you would need to export a parasolid of the assembly and then import the para solid back in to a clean part file, this will leave you with a series of solids, but no assembly.
Cheers
Si
Best regards
Simon NX 7.5.4.4 MP8 and NX 8.5 (native) - TC 8 www.jcb.com
 http://files.engineering.com/getfile.aspx?folder=76558d1d-4bdf-4912-b428-516219ec6cc3&file=step.jpg
just select flatten assembly box while importing from import options...
