Hi all!
I would like you to help me to understand the concept of pressure in pipes where there is an incomprehensible fluid.
I imagine a pump with a pipe full of water and a valve at the outlet.
I understand the curves of the system and of the pump, to see which pump satisfies the conditions of my system (head, pressure drop, etc.).
What I find difficult to understand is the concept of pressure (in gases I don't have such a problem as they are volume dependent and can be compressed).
Imagine that for the attached system, I need 5 bar of pressure at the discharge for a flow of 30 L/s at the outlet. The pressure gauge at the pump discharge will show 5 bar, but what does that imply? That the water pipe full of water is exerting a force of 5 kg per cm2? If I throttle the valve, the pressure will rise to 8 bar for example. In both cases, the pipe is completely filled with water, isn't it? So what is the basic principle of the manometer to know that it is 5 or 8 bar? Is it because a column of water is displaced?
I don't know if I'm making myself clear. In short, my doubt is:
1. to understand the concept of pressure in a pipe, given that if the pipe is always full of water regardless of the flow rate, what does it mean that a manometer reads 5 bar or 8.
2. If fluids are incompressible, what happens if the pump keeps pumping fluid against a valve that is closing? I don't understand how ‘more water gets in’ if the pipe is completely full.
Thanks a lot! Sorry I am not explainning correctly, it is also hard for me how to put an example
