taliban999
Materials
- Mar 10, 2025
- 7
Hello All
When access from both sides are not possible, like welding clad pipe to clad pipe, generally the full joint is welded with the high alloy. (Clad pipe is CS(ASTM A234 WPB) + Incoloy 825). In this case Er Ni CR Mo-3 and E NiCrMo-3 is used. This has been my experience.
Now a contractor is suggesting to use the following weld sequence(And is willing to support with a PQRT)
1) 5 mm incoloy will be welded with Er NiCrMo-3
2) Next pass with E309, maybe 2 layers
4) Complete the joint with 7018.
A) These ways are cheaper than my ways. But can it be done?
B) Is there any documentation specifically on this CRA pipe welding?
Thank you for answering me.
