how to jump error in nxopen and continues working macro 1
NETGARA
New member
Jun 3, 2020
8
Good morning,
I have the following problem, I would appreciate if someone could help me.
I want to make a macro that intersects surfaces by multiple planes, some surfaces are bigger than others and not all planes always intersect with small surfaces, generating an error and stopping the macro ..., which code I have to use to jump the error and the macro continues to work?
Thank you very much for your help.
The various languages supported by NXOpen use different approaches to error handling. If you are using a .net language (VB or C#), you can use the Try Catch block.
www.nxjournaling.com
Yes, i`m using .net, but i never use try catch block. How is the error condition indicated?
Thank for your help cowski!, i follow the sample and i got it. I summarize the method i use.
for a= 1 to repetitions
Try
(code for intersection)
catch ex as NXexception
MessageBox.Show ("NX exception: " & ex.Message)
End Try
Next
