budaryah
Materials
- Jan 17, 2012
- 4
I am a researcher in civil engineering materials specializing in asphalt mixes. I am doing research in recycling idusterial solid waste as a construction material.I have used waste materials in concrete and asphalt in the past. I am trying this time to utilize two wastes in clay bricks which is a new area to me. The first waste is a spent Zeolite catalyst pwder (Ecat) generated from oil refinary operations. The seconed waste is an air dried solid sludge cake obtained from the textile effluent treatment plant, which will be pulverized before mixing with red clay.
I am thinking to prepare 70X70X70 mm cubes and fire them in a muffel furnace at different emperatures. I am not sure how to properly mix the materials to get red of all the air inside and avoid cracking during the firing process. Any ideas, standards, and specifications for the mixing, firing and the testing to evaluate the new products and compare them to the standard normal clay bricks ?
