MosBrowning
- Mar 17, 2013
- 5
Dear all
I'm modelling a Steel column base plate subjected to Moment ,the model is fine and output results are quite reasonable.
Now I'm validating the Model with Experimental test results that have Moment - versus - rotational angle in radians plotted in curves.
so the question is :
Is it possible to obtain the base plate rotational angle at a certain vertical cross section or not ?
if not, shall I start to calculate this rotational angle manually (which might be quite inaccurate) ?
Thank you in advance
Regards.
Regards.
