How to model infinite part for axisymmetric elements in Abaqus?
kumara123
Geotechnical
Jun 13, 2016
26
Hi, I am trying to model an infinite boundary for 2D soil media with different layers in Abaqus.
I want to add an infinite part to the axisymmetric elements. I tried that with defining acoustic elements (ACAX4) and then convert into infinite elements (CINPE4) in .inp file. But it was done by a mixture of 2D and axisymmetric elements. Is this ok or can anyone recommend me a method?
Also, how to assign different material properties to different layers after obtaining the infinite elements (it becomes an orphan mesh part).
 http://files.engineering.com/getfile.aspx?folder=657cb44f-3b7d-4a8e-b17b-a15b574eaa95&file=Capture.PNG
Dear kumara123
Hello
I have the same problem as you mentioned. Please help me know if you found the solution of this problem.
Thank you
Mehdi
Dear Mehdi,
I used the same method I explained in the problem and convert the ACAX4 elements into CINAX4 in .inp file.
Is that the answer you want?
Thanks,
Kumara.
Dear Kumara
Thank you for your help.
I am trying to work with orphan mesh, but I have some problems. Do you have any references about orphan mesh and how it works?
Best regards
Mehdi
Dear Kumara
thanks a lot. I saw these videos and they are great. I have problem with assign different material properties to different layers after obtaining the infinite elements with orphan mesh.
Mehdi
Does the problem relate to grouping elements into different layers or some other problems?
