hi all,
do someone know how to model screw in assembly ? A spring, a beam, somthin' else ...
and especially in plastic assembly...as screws in Polypropylen assembly ?
Normally if your assembled parts are modeled whit shell elements and you want stress in your screw you can use beams (with the section properties like your screw) as for bolts or rivets. In the hole you must build a spider.
