How to process all detailviews? 1
niedzviedz
307
I wanna process all detail views to change label on it. Below is my code, but I receive an error "cannot convert detailview to 1-dimensional array view."
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
	Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
	Dim workPart As NXOpen.Part = theSession.Parts.Work
	Dim displayPart As NXOpen.Part = theSession.Parts.Display
Sub Main (ByVal args() As String)
	Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
	markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
	'Dim views1(0) As NXOpen.View
	'Dim detailView1 As NXOpen.Drawings.DetailView
	Dim startSheet As Drawings.DrawingSheet = theSession.Parts.Work.DrawingSheets.CurrentDrawingSheet
	'for each views1 as Drawings.DraftingView in startSheet.SheetDraftingViews
	for each dview as NXOpen.Drawings.DetailView in startSheet.SheetDraftingViews
		'views1(0) = detailView1
        'If views1.Name.Contains("DETAIL") Then
		'for each dview as NXOpen.Drawings.DetailView in views1
			Dim editViewSettingsBuilder1 As NXOpen.Drawings.EditViewSettingsBuilder = Nothing
			editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(dview)
			theSession.SetUndoMarkName(markId1, "Settings Dialog")
			Dim editsettingsbuilders1(0) As NXOpen.Drafting.BaseEditSettingsBuilder
			editsettingsbuilders1(0) = editViewSettingsBuilder1
			workPart.SettingsManager.ProcessForMultipleObjectsSettings(editsettingsbuilders1)
			'editViewSettingsBuilder1.ViewDetailLabel.LabelParentDisplay = NXOpen.Drawings.ViewDetailLabelBuilder.LabelParentDisplayTypes.LabelOnBoundary
			Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
			markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Settings")
			theSession.DeleteUndoMark(markId2, Nothing)
			Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
			markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Settings")
			Dim nXObject1 As NXOpen.NXObject = Nothing
			nXObject1 = editViewSettingsBuilder1.Commit()
			theSession.DeleteUndoMark(markId3, Nothing)
			theSession.SetUndoMarkName(markId1, "Settings")
			editViewSettingsBuilder1.Destroy()
		'next
		'End If
	next
End Sub
End Module
Any tips how to repair it?
With best regards
Michael
Code:
Option Strict Off
Imports System
Imports NXOpen
Module process_detail_views
    Sub Main(ByVal args() As String)
        For Each dview As NXOpen.Drawings.DraftingView In startSheet.SheetDraftingViews
            If Not TypeOf (dview) Is Drawings.DetailView Then
                'skip non detail views
                Continue For
            End If
            editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder({dview})
        Next
    End Sub
End Module
www.nxjournaling.com
Thanks @Cowski. So the main problem was with calling view.
Code:
Why is {} so important?
With best regards
Michael
The curly braces tells the compiler to treat the variable as an array. It acts as a sort of shortcut to the following code:
Code:
dim myDetView(0) as DetailView
myDetView(0) = dView
editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(myDetView)
Thanks @Cowski, now it's all clear.
With best regards
Michael
