How to re-order Sheets in Drafting?
potrero
516
Is it possible to change the order of Sheets in the Drafting module? (ie: take Sheet 6, and move it to be Sheet 4 ...)
Rename SH 4, rename SH 6 to SH 4, then remane SH 4 to whatever...
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - [small]Thomas Jefferson [/small]
You can follow the same process to insert a sheet in between existing sheets if you need to. However, if you use the system attributes for the sheet number X of the total number of sheets Y, these do not get updated if your rename the sheets as ewh describes, so you will have to override them with manual text. There is an ER regarding this issue so perhaps in a future release it will work better.
I've found that NX prints the sheets in the order in which they were created, so renaming them doesn't really accomplish what a true reordering would.
Hopefully this will be addressed soon. I'd like to see the sheets renumber themselves when a new sheet is inserted.
Ed
Unless someone contacts GTAC and have them open a PR or an ER, I suspect that no one will be 'addressing' this, soon or otherwise.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
...if you use the system attributes for the sheet number X of the total number of sheets Y, these do not get updated
I never caught that before, thanks.
It does update the sheet total, though.
I submitted an ER for this some time ago actually, though I would encourage others to do the same.
