How to restrict the interference between Elements in ABAQUS?
Sabeel Mehmood
1
I am doing 2D simulation of machining (Turning) in ABAQUS software. I have used the surface-surface contact between Workpiece and tool , and self-contact on the upper surface of Workpiece. When I see the results, and play the simulation, the chip is interfering/merging inside the workpiece element.How to avoid this interference?
 https://files.engineering.com/getfile.aspx?folder=fe1cce5f-6bf0-4789-bf17-526212285351&file=Query.png
Try using general contact (in newer versions it works with 2D models as well). Adding interior surface for erosion may also help.
