How to specify nylon heat stabilization? 1
dgallup
Automotive
May 9, 2003
4,715
I have often seen different grades of nylon listed as heat stabilized, but there does not seem to be any performance data to say how effective is the heat stabilization. Is there a standardized way to specify this? I want to add it to one of our company material specs but it doesn't seem adequate to just add the term "heat stabilized" without any criteria.
Thanks, I don't normally double post but didn't get any response in Polymer Engineering so I tried here. I read your link and googled related subjects. While I did find outfits selling test equipment and some studies on polyethylene and polypropylene, I can't find any data on nylons using the Oxidative-induction time test method.
You may find this useful:
The thing is that there is no simple answer to your question. There are many degradation mechanisms involved and every application has a different sensitivity to material degradation. So there are numerous tests which can be extrapolated in several ways.
Thanks, that will certainly give me a lot to explore.
This is a manufacturer specific brochure, but page 45 gives some idea of a possible way to quantify a heat ageing specification.
EMS Grivory
www.tynevalleyplastics.co.uk
Politicians like to panic, they need activity. It is their substitute for achievement.
