How to support a horizontal tank
Peace10
8
Hi everybody
I have a tank placed on a cradle of 3.6 m of long and I want to size the sole on which I will attach the cradle. which type of sole do I choise? and how can i calculate its dimension?
A lot of factors come into play. Does the cradle sit uniformly on the concrete pad or on 4 legs? how heavy is the tank when fully operational? What kind of soil?
At the risk of sounding preachy you need a geotech engineer to do soils investigation at the site to give you soil parameters, then you need to hire a structural engineer to design the concrete pad.
What you are designing is called a tank saddle. I agree with Jayrod...you need to know some soil conditions and the structural loadings to design both the concrete footing and the saddle. Assuming this is a steel saddle, you will have a high buckling load directly under the tank. The saddle base has to be large enough such that you do not impose too high of a shear load on the concrete and large enough so as to prevent crushing the concrete (not likely).
As others said, you must look into the soil that you want to put the load on. It would be bad new to put a good tank on a poor soil and/or the wrong type of base support.
Depending in where you are, there may be some seismic factors. I doubt that the manufacturer includes those because they are highly variable.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
