How to transfer roof truss loads to steel columns if the truss analysis is localized
teach_me
20
By localized i mean just 1 section member with tributary area. How do i go about the load path? Truss is analyzed as simply supported. Steel Column is supposed to be pinned, so also how do I model bracings which are steel rods only. What releases should i go for at the ends?
Cant really understand, why don't you post ur input file.
I guess it wasn't that important after all.
