ferro1001
Automotive
- Aug 11, 2004
- 32
I have to model the ceiling of a bus in an impact essay in dynamic Explicit. The ceiling has an upper shell of glass fiber composite sticked to an structure of bars that I have modeled with beam elements, and beneath it another shell of plywood. I have tied them with the TIE CONSTRAINT, but it finishes failing. I think that the master surface should be the structure of bars and the two shells should be the slave surfaces, but the shells´ mesh is much more coarse than the bars´, and the tutorial says that that could make it fail. I have read something about using spot welds that do not depend on meshing, but I don´t know how to use them. Coul anybody help me?
Thanks in advance,
ferro1001
Thanks in advance,
ferro1001
