corus
- Nov 6, 2002
- 3,165
The number of High Strength Friction Grip bolts required to satisfy shear stress requirements through the tensile stress area is much less than the number of bolts required to prevent slip (using BS5950). These bolts are supposed to work by passing the load through the frictional forces between the two connections and not through the bolts. Does it matter if the surfaces slip?
corus
corus
