Human-powered impellar pump question
bd103dall
8
I am part of a humanitarian group which is designing an irrigation pump for farmers in Malawi. The pump itself is powered by an individual pedaling a bicycle, where an additional chain is connected from the rear bicycle gears to a gear around a shaft (a few feet behind the pump). The shaft then rotates and in turn powers an impellar pump which pumps the water through a hose (impellar is a propellar designed for water that as it turns pumps water).
Does anyone know a company that designs impellar pumps that work with the low power input of our device (approximately 1/8th a horsepower)? Most pumps that I have found are designed to be used in conjunction with a motor which has a much higher power output and in turn much higher rpms than are possible from our human powered device.
Any help is appreciated, thank you.
BigInch
Thanks for the last posting re human output against pump performance - very informative and useful. However, the data you have found appears to be based on maximum output for a human whereas we need to be more conservative in the expectations.
I think in the situation for this application we would be happy with 4-5 l/m @ 5-6 m head something that is capable for 1 or 2 people working together for a few hours.
bd103dall
I will contact you with few more questions as this project is of interest to me as I am now retired with time on my hands and have some background in aid projects - although this has been at the top end of the spectrum where money wasn't a problem with most of it going on consultants - but that's another story.
I didn't know if the application was for drinking water or small scale irrigation. These curves are for centrifugals anyway. As was said above, a piston pump may be more appropriate. They are power limited too, so easier to specify the correct cylinder size and strokes.
Find my e-mail in the contacts section of my webpage, drop me your address and I'll send you lower flowrate/higher head numbers at maybe half the power output.
