MeDesignEng
I recently design an AHU above ceiling unit with a condensate pump located in the emergency drip/overflow pan. The contracter left me a comment stating that whenever possible the condenstation from the HVAC equipment should be a gravity flow drain and not rely on mechanical means for discharge. He recommended using a hub drain with a trap primer under a near by sink instead. I see know that this may be a better option but I wanted to get a second opinion, or see if anybody else had a better option.
