Depending on one manufacture to design and supply a complex system that will work flawlessly is not going to happen in any area, hydraulic, electric, electronic control, machining, fabrication, ect.
No one manufacture supplies best of breed in all hydraulic components, yet they will use marginal components to be sole supplier. I use components from both Sun and HydraForce even though they make products that do the same function. The reason is, each company has their own design for different valves and one may out perform the other is specific applications, the only way to find out is to test. If simple projects are failing, then the information given to the supplier must be suspect, not everyone can screw up every project.
We just went through a problem with a machine tool where the ladder logic and user interface would not work correctly or the same every time you pushed a button.
Simulation software will help, but if every detail is not set and followed, the results will be different. The size and in some cases changing the ID of a tube or the manufacture of the fitting or hose end will compromise the system. Long runs of pipe or hose can have ill effects. Then some problems are freak. I designed a system using a HydraForce CV08-21 check valve. The flow was high enough that the back pressure was a little to high, so I installed a CV10-20. This valve caused a malfunction. After much testing and instrumentation, we found the designs were different and the CV10 could float open during a pressure balance condition. Some things in life, are just learned the hard way, trial and error. No software could simulate these valves to determine if this condition existed as HydraForce didn’t know this could happen. Obtaining values for hydraulic valves would require testing valves constructed with minimum, average, and maximum tolerance, then using that range for simulation. The next problem would be hose, hose ends and fittings.
