Helepolis
- Dec 13, 2015
- 206
Hi all,
I need to replace a plastic 3ml syringe on an experimental setup to something more robust.
The syringe acts as a miniature pump, and the pumping action is at a very high frequancy which results in leakeges of air in to the system.
The substance that the syringe is pumping is water mixed with glicerol.
I was wondering if a small pneumatic cylinder will do the job, or I have to find an hydraulic cylinder that can handle liquids less viscous than oil?
The reason I'm asking is that I have little experience with hydraulic and pneumatic cylinders.
