Hydro-static Tests Need a faster way
Jness
Hi All,
My company manufactures 2ft x 4ft all the way up to 3ft x 8ft ASME CODE pressure vessels. We manufacture about 15 a week and currently are spending hours just filling and pressure testing these. Theres got to be a faster way to do this.
Does anyone have a good set up that they could share picture?
Does anyone know of a place where I can purchase a system to fill and drain pressure vessels very quickly?
You are limited by the largest opening in the vessel. I suggest you fill using low pressure high volume water. Once filled increase pressure to Hydro pressure with low volume high pressure water. We use a pressure washer pump for this.
A 2' diam x 4' S/S vessel is not a particularly large volume. What are you using to fill and drain now? What is the limiting component? And how much time are we talking about (2 hours total to test 15 vessels? 2 hours per vessel?)?
This is the best filling system I've encountered. It also empties quickly on warm days.
[URL unfurl="true"]http://www.bottomsupbeer.com/howitworks/How-It-Works.html[/url]
To save the draining time, hook up the air hose and push the water out after testing
Jness said:
There's got to be a faster way to do this
Well if you could actually describe what your current method is, line sizes, flowrates, durations etc, then we might be able to provide some more detailed ideas rather than the general posts so far.
Where are you identifying the bottlenecks / things that take a long time?
Filling rates?
Pressurisation?
Inspection of the vessel?
Emptying?
Drying?
What are your limitations (size / area, water flow, disposal, cost of water)
All these things make a difference which is why no one solution fits all issues.
Pipe mills test hundreds of pipes a day and have water spraying everywhere and the test lasts 10 seconds or so. Some place only test one vessel a month. different systems.
