HYDROCARBON ANALYZER - IS IT HAZARDOUS AREA DEVICE ?
bobziva
41
0
0
YU
Hydrocarbon Analyzer is it a hazardous area device ? The analyzer is provided to be installed in special room for the monitoring of hydrocarbon contamination. That room is potential hazardous area, and Owner wants to discuss about that.
I used to read many prospects / catalogues about hydrocarbon analyzer and manufacturer always stops the process if something wrong, but never provides information about their product as hazardous area device.
Thank you for any info / article about that.
do you mean if the unit can leak - or exhaust something that could cause the area to become classifiable (eg zone 0,1 or 2?)
Best regards
Morten
If by your phrase "hazardous area device" you mean are they considered "safe" for installation in areas where explosive and/or combustible vapors may be present, we have found that they are not. We install them in enclosures with continuously supplied purge air on our platforms.
Dear Sirs,
Thank you for coments, but I repeat, Hydrocarbon Analyzer is provided to be installed in special room for the monitoring of hydrocarbon contamination.
We have to make order for that Hydrocarbon Analyzer, but we have a couple questions :
(1) Hydrocarbon Analyzers, available on the market,are provided for permanent operation or not ?
Owner prefers permanent testing operation. What do you know about that ? What is your suggestion about maintenance, how to minimize maintenance ? ( cleaning of the pipes etc.)
Are you suggesting Time-Relay for the control of testing operation from time to time, or maybe you have a better solution. We are trying to minimize maintenance.
Are you suggesting ventilation ? ( fans)
(2) Area provided for installation of the Hydrocarbon Analyzer is non-hazard area but as soon as analyzer
is installed there that area becomes hazardous area because of flammable gas inside a pipes ( hydrocarbons).
Did you provide Hydrocarbon Analyzer as equipment for Hazardous Classification Area. ?
Sincerely,
Bobziva
Gas inside pipes does not make an area hazardous (only the volume INSIDE the PIPES but thats a technicality). But if you have a vent on the unit or high risk of leaks (through seal or other potential sources) then the area might become classified.
Best regards
Morten
