srihari5043
Chemical
I am in process of calculating depressurization rate for condensate dehydrator .
LPG condensate composition as follows :
Component Mole %
NITROGEN 0.0009
H2S 0.0009
CO2 0.0028
METHANE 0.0911
ETHANE 0.1548
PROPANE 0.3015
i-A-BUTANE 0.0805
n-A-BUTANE 0.2154
i-PENTANE 0.0503
n-PENTANE 0.0612
n-HEXANE 0.0307
n-HEPTANE 0.0089
I specified the following for the depressurization module in HYSYS:
Total System Volume 87.1 M3
Liquid Inventory 87.1 M3
Wetted Surface area 117.2 M2
Initial Pressure 58.6 BarG
Initial Temperature 37.8 Deg C
Orifice size 400 mm2
Flow equation supersonic
Valve type Liquid
Environmental Factor 1
Heat flux Model API521
PV Work Term Contribution = 93%
Coefficient of Discharge for Orifice = 0.84
Results of simulation showing out let temperature are in negative
Can any facing the same problem... please share your experience
please check the hysys simulation on the hyper link.
Component Mole %
NITROGEN 0.0009
H2S 0.0009
CO2 0.0028
METHANE 0.0911
ETHANE 0.1548
PROPANE 0.3015
i-A-BUTANE 0.0805
n-A-BUTANE 0.2154
i-PENTANE 0.0503
n-PENTANE 0.0612
n-HEXANE 0.0307
n-HEPTANE 0.0089
Valve type Liquid
