I need help with a technical mechanics task
KalleKK
Student
Mar 21, 2024
I am a student who need help with a problem
Point and line loaded, cantilevered end, steel cross section. Material properties fm =355 N/mm2, fv `= 204 N/mm2. E 210,000 N/mm2. Cross section unknown. Steel IPE profile and rectangular section pipe. Dimension the steel cross section and check the stresses.
What help do you need?
Start by drawing a free body diagram. Then use statics to get the stresses.
I need to find the cutting force, bending moment and tension. I have tried to solve, but the answers don't come out. I need to use the formula V/ As - to find the force.
