preecher
- Jul 7, 2003
- 1
I have a threaded hole and a clearance hole in two parts that are to be bolted together. The clearance hole diameter is roughly .031" larger than the bolt nominal diameter. I've told the designer he should use Ø.010mmc tp for the clearance hole and Ø0.020mmc tp for the threaded hole, thinking that the threaded hole would be more difficult to hold tighter than the clearance hole and that measuring the threaded hole is more difficult. However, the designer is also being told (by another) to reverse those tolerances. I don't want to cause problems, so I want to know if there is an manufacturing rule of thumb or standard that would indicate which way the tolerance imbalance should fall.
