Impact Force, Cantelever Beam, Elastic
JustinME
27
Background Informatiom:
I have a problem that requires the input of impact force data into an FEA for structural design. I have a machine with two front wheels and one rear caster. The wheels and caster are suspected to have implications on strength requiresments of the machine frame; therefore, to minimize the total cost of frame, wheels, and caster I am investigating the effect of different wheel and caster designs on frame strength requirement. In other words, I can pay for a more expensive caster or wheel if it allows me to design a sufficiently less expensive frame. In this problem, I will only be dealing with the rear caster.
The machine CG (center of gravity) is between the front wheels and rear caster, and rather high so that ramp angles shift the machine weight between front wheels and rear caster.
The impact force of concern is the result of driving the machine off a three inch tall curb or ledge. To simulate this scenario, I placed the placed the front wheels of the machine on a lift table and I held the rear of the machine with a quick release trigger so that the rear caster had three inches below it and the "ground". Now what I refer to as the "ground" is actually a load cell that will measure force versus time. I also have an accelerometer mounted to the top of the caster mounting plate, so there is a load cell at the bottom of the caster and an accelerometer at the tope of the caster so elasticity of caster tread will cause some differences and/or lag between force and acceleration measurements.
The rear caster is attached to the machine via a stiff (not rigid) beam. The wheels are directly attached to the machine frame.
Test Conditions:
The machine began level with the ground and the rear of the machine was suddenly dropped three inches (rotational motion about the front wheel axis). A small DOE was run so that there was two different caster tread hardnesses tested and two different weights applied to the caster. The caster loading was measured at the end of each test run because the weight distribution had changed (ramp angle) and because the weights in the machine were launched slightly out of position (this represents real-world application, although not ideal for testing).
The low weight tested was 60 lb and the high weight tested was 90 lb.
The hard caster tread was Shore D 95 (phenolic material), and the soft caster tread was Shore D 15 (neoprene material).
Data:
Impact forces (load cell measurements) for both casters was approximately 700 lb for the low caster loading condition and approx 1050 lb for the high caster loading condition.
The data shows that the impact force measured is linearly correlated to the weight placed over the caster (at the end of the test, with the machine 3" out of level) with an r^2 value of 82.1%. Therefore, the wheel hardness had close to zero effect on measured impact force.
The soft tread caster had g-loads (acceleration) of 15 g's for both high and low caster loading conditions.
The hard tread caster had g-loads of 55 g's for both high and low caster loading conditions.
The data shows that tread hardness has a significant effect on measured acceleration during impact.
Problem Statement:
The force measured at impact is the same for the soft and hard caster tread, but the acceleration values are different by a factor of ~3.7. I do not know if I should use the measured g-loads (acceleration divided by gravity) or if I should use the force loads. I do not believe that the tread hardness has no effect on machine frame stress during impact, but my superior engineer (almost boss) does believe that the tread hardness should not effect impact forces the frame must support.
Questions:
1) What force should I use in my FEA in order to calculate stresses in the cantelevered beam that the caster mounts to?
2) Can anyone explain why the measured force is not effected by tread hardness?
3) My superior engineer said that the resonant frequency of the frame (i.e. system) that attaches the caster and wheels to the machine must have some resosnant frequency that forbids/prevents the tread hardness to eefect the impact force...which he knows because he used to do isolation designs for computer parts.
4) Is there a way for me to upload JPEG files of my Free Body Diagram, test results, etc. onto this forum?
Thanks in advance for your help!
Justin
The problem is reasonably well explained but some drawings would certainly help- the machine, its attachments to the frame, the original frame and wheels and the path environment.
Use translation assistance for Engineers forum
Note the rules include No Student posting
If the peak force is virtually identical and the peak accelerations differ by a factor of 4 then Mr Isaac Newton and your almost boss would agree that a different mass is involved. Using F=ma you might have a go at working out the mass in each case. Is the wheel mounted on some sort of suspension? Is the time history of the waveform the same for both tread hardnesses?
I would build a simple 2 dof spring mass system and see if I can understand the time histories with that.
If you carefully optimise everything for a 3" drop, what will happen in the case of a 4" drop?
Cheers
Greg Locock
wouldn't the harder tire be less resilent ? and so the impact event would take less time. and so higher accelerations and higher forces are expected, no?
maybe you can investigate the resonance suggestion by slightly changing the test conditions ... 2.5" drop, 3.5" drop. highly corelated results (linear?) would suggest against resonance.
Quando Omni Flunkus Moritati
As GregLocock suggests, the time histories should be different, peak forces should be different. Average forces may be as measured.
Ted
i think "state 2" (static balance after the impact) shouldn't show the acceleration vector.
i think the acceleration exists during the impact, when the cart is still pivoting about the front wheels. you know how much energy the cart has before the contact. the ground opposes this energy with a contact force (through the resilent tire), and this causes the cart to decelerate.
GregLocock -
There are no differences in mass. The two different casters each weigh within 0.01 lb of each other, purely by coincidence. The machine weights were not different between casters; however, the low caster load required a machine weight of ~12 lb less than the high caster load.
I can't technically say that the caster is mounted via a suspension system, but I can say that the caster is attached to the frame by a short piece of sheet steel so some flexibility exists. I cannot see the steel deflect or bend when I put my body weight on it (175 lb).
I do not understand how to do this time history analysis you speak of. Can you explain, or direct me to a textbook, or give me a technical name I can research? I'll attach data plots for acceleration and force in separate replies.
Also, the machine contains 10 gallons of water that sloshes around immediately after the impact which may cause some of the oscillations seen in the four plots above.
rb1957 - the acceleration vector is shown only to communicate the direction in which acceleration is being measured. In oher words, I have a single axis accelerometer measuring in the direction parralel to the caster swivel axis.
Where exactly are the forces and accelerations measured/calculated?
TTFN
faq731-376
7ofakss
is the time axis right for both accel and force ? or is the phase shift expected and reasonable ?
I'm thinking that the force is a calculated/filtered thing, which may be where the lag comes from. The accelerations are measured, but forces generally are not.
Also, the acceleration plots correlate with the notion that a squishier wheel would result in prolonging the impact, which is borne out by the duration of the force curves. The prolonged impact is where the peak accelerations wind up being different.
TTFN
faq731-376
7ofakss
IRstuff -
The force is measured at the bottom of the caster wheel. The caster is colliding with the force gage.
The acceleration is measured on top of the steel plate to which the caster is mounted, directly over the caster swivel bearing axis.
The force is measured with a strain type force gage and not calculated.
The acceleration is measured with an accelerometer, probably the type that measure the resulting vibration of a crystal.
rb1957 - I see two phase shifts, so I'll address them both.
Phase shift at beginning of data: The accelerometer outpust data slightly before the force gage, and I do not believe the time shift is reasonable. The point of impact is the point where the force is measured (well, there is a two inch thick aluminum plate between the caster and force gage). The accelerometer is at the opposite end of the caster, which is about 4 inches away. I brought this up to my test engineer and he is so far convinced the data is correct and my theory is incorrect.
Phase shift between peak acceleration and peak force: I think it is reasonable for peak force to occur after peak acceleration because peak force should exist when all material are fully compressed and at that moment the acceleration should be instantaneously at zero...then the force should reduce and acceleration should be in the opposite direction as it was just before the force peaked. I suspect peak acceleration should exist at the instant of impact, and peak force should exist moments later when the parts are all fully compressed given their respective spring rates (stiffness, or elasticity).
