mkiragu
Aerospace
- Oct 4, 2021
- 4
Hey,
I have read through threads, videos and literature but cant seem to get a straight answer so seeking some help. It is correct to say that it is not wise to have a part that has Datum feature tolerance larger than the positional tolerance of a hole?
Background:
I have a drawing of a part where the datum itself a profile of a surface has a tolerance of 3mm and the holes, which are present on opposite sides of feature have a positional tolerance of 1.0. Problem is the part is subject to twist and pitch on datum A, so throwing hole positions way out.
Am I wrong is assessing that the datum tolerance should be tighter and that the part needs to be constrained to remove twist to ensure it reflects machining? Part is large composite panel.
Background:
