jithus
- Mar 28, 2010
- 13
Hello all,
Before submission of my query, I would like to appreciate the forum members helping each other out through great suggestions. I seek a new one to solve my problem too.
Model: I'm simulating an Impact problem in Abaqus Explicit for a 3D composite plate made of 21 plies and meshed with linear brick elements. The impactor is modelled as a rigid body with Ref point and moving with initial velocity of 7.08m/s and mass of 260gms.
In my simulation I'm also using a VUMAT subroutine for the composite.
Problem: The simulation runs but in the results output I see that the impactor is penetrating into the composite. The property definitions are correct. Since this is a Low velocity impact, the impactor should only bend the plate but this is not happening.
I suspect problems with contact conditions but have tried almost all options. Presently it is a surface-surface contact with kinematic condition.
Attached is the description of the complete model I'm trying to simulate.
Has anybody come across a similar problem? Can you suggest areas to look into to correct the problem?
