Import lines to NX4 1
pitertxuss
Industrial
ES
Hello every body,
I would like to import lines to a cad model. I have in a worksheet the lines defined by points (x,y). I know how to import those points, but I can´t import a line. It´s possible? for import the points I´m using "file2points" file.
Thanks!!
Inside of NX's database lines are defined simply as two points. So if you have the points imported, that all that you need. Granted, you will now need to actually create the 'line' objects, but you already have the data needed for the job.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here is a quick & dirty edit that will import the pairs of points in the file as lines. This may not do exactly what you want, but should serve as an example of how to create the lines from your given points.
Code:
[COLOR=blue]Option[/color] [COLOR=blue]Strict[/color] [COLOR=blue]Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] System.IO
[COLOR=blue]Imports[/color] System.Windows.Forms
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Module[/color] Module1
    [COLOR=blue]Sub[/color] Main()
        [COLOR=blue]Try[/color]
            [COLOR=blue]Dim[/color] openFileDialog1 [COLOR=blue]As[/color] [COLOR=blue]New[/color] OpenFileDialog()
            openFileDialog1.Filter [COLOR=blue]=[/color] "txt files (*.txt)|*.txt|All files (*.*)|*.*"
            openFileDialog1.FilterIndex [COLOR=blue]=[/color] 1
            openFileDialog1.RestoreDirectory [COLOR=blue]=[/color] [COLOR=blue]True[/color]
            [COLOR=blue]If[/color] openFileDialog1.ShowDialog() [COLOR=blue]=[/color] DialogResult.OK [COLOR=blue]Then[/color]
                [COLOR=blue]Dim[/color] theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
                [COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
                [COLOR=blue]Dim[/color] sr [COLOR=blue]As[/color] StreamReader [COLOR=blue]=[/color] [COLOR=blue]New[/color] StreamReader(openFileDialog1.FileName)
                [COLOR=blue]Dim[/color] line [COLOR=blue]As[/color] [COLOR=blue]String[/color]
                [COLOR=blue]Dim[/color] startPoint [COLOR=blue]As[/color] Point3d
                [COLOR=blue]Dim[/color] endPoint [COLOR=blue]As[/color] Point3d
                [COLOR=blue]Dim[/color] i [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] 0
                    line [COLOR=blue]=[/color] sr.ReadLine()
                    [COLOR=blue]While[/color] [COLOR=blue]Not[/color] line [COLOR=blue]Is[/color] [COLOR=blue]Nothing[/color]
 [COLOR=green]'Dim pt As Point3d[/color]
                        [COLOR=blue]Dim[/color] delim [COLOR=blue]As[/color] Char() [COLOR=blue]=[/color] {","c}
                        [COLOR=blue]Dim[/color] strings [COLOR=blue]As[/color] String() [COLOR=blue]=[/color] line.Split(delim)
                        endPoint.x [COLOR=blue]=[/color] Double.Parse(strings(0))
                        endPoint.y [COLOR=blue]=[/color] Double.Parse(strings(1))
                        endPoint.z [COLOR=blue]=[/color] Double.Parse(strings(2))
                        [COLOR=blue]If[/color] [COLOR=blue]Not[/color] IsNothing(startPoint) [COLOR=blue]Then[/color]
 [COLOR=green]'create a line from startpoint to endpoint[/color]
                            workPart.Curves.CreateLine(startPoint, endPoint)
                        End [COLOR=blue]If[/color]
                        startPoint [COLOR=blue]=[/color] endPoint
 [COLOR=green]'Dim p As Point[/color]
 [COLOR=green]'p = session.Parts.Work.Points.CreatePoint(pt)[/color]
 [COLOR=green]'p.SetVisibility(SmartObject.VisibilityOption.Visible)[/color]
                    End [COLOR=blue]While[/color]
                [COLOR=blue]Finally[/color]
                    sr.Close()
                End [COLOR=blue]Try[/color]
        [COLOR=blue]Catch[/color] E [COLOR=blue]As[/color] Exception
            MessageBox.Show(E.Message)
    End [COLOR=blue]Sub[/color]
    [COLOR=blue]Public[/color] [COLOR=blue]Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
 [COLOR=green]'Unloads the image when the NX session terminates[/color]
        GetUnloadOption [COLOR=blue]=[/color] NXOpen.Session.LibraryUnloadOption.AtTermination
    End [COLOR=blue]Function[/color]
End [COLOR=blue]Module[/color]
www.nxjournaling.com
thanks!! I will go to try! I´ve never used the journal before, so I have to try it.
In what format should be the coordinates in the file?
My file looks:
264.560,-259.448,-18.276
263.969,-259.748,-18.302
263.374,-260.040,-18.328
262.776,-260.325,-18.354
262.174,-260.602,-18.380
266.889,-258.178,-18.274
and the result: Input string was not in a correct format.
kukelyk
Your test data appears to be in the correct comma delimited format. I ran a test on your posted data and it worked. I suspect this is only a small portion of your data; does the data file have headers or blank lines? If so, they may cause problems. The journal uses Double.Parse to convert input to numbers, if there are other non-numeric characters in the file it may also cause such an error.
After I removed all empty lines, the error is the same..[mad]
kukelyk
With the exception of an extra line from (0,0,0) to the first point in the file, it works fine for me.
What language is your computer set to use? I suspect it is a .NET setting that is interpreting your input differently than what my computer is using (reference thread561-315066 for another example). If your computer language is something other than English, perhaps we can "borrow" petulf's fix from the other thread.
Below is the updated code to get rid of that extra line.
Code:
                [COLOR=blue]Dim[/color] startPoint [COLOR=blue]As[/color] Point3d  [COLOR=blue]=[/color] [COLOR=blue]nothing[/color]
				Dim firstPass [COLOR=blue]as[/color] [COLOR=blue]Boolean[/color] [COLOR=blue]=[/color] [COLOR=blue]True[/color]
                        [COLOR=blue]If[/color] firstPass [COLOR=blue]Then[/color]
							firstPass [COLOR=blue]=[/color] [COLOR=blue]False[/color]
						Else
                    sr.Close()
Thanks, but still not resolved, the same error..
Code:
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Module Test
    Sub Main
                Dim session As Session = Session.GetSession()
                Dim line As String
                    line = "264.560,-259.448,-18.276"
                        Dim pt As Point3d
                       ' Dim delim As Char () = { ","C }
                        Dim delim As Char () = { "," }
                        Dim strings As String () = line.Split(",")
session.ListingWindow.Open
session.ListingWindow.WriteLine( strings(0) )
session.ListingWindow.WriteLine( strings(1) )
session.ListingWindow.WriteLine( strings(2) )
                        pt.x = Double.Parse(strings(0))
                        pt.y = Double.Parse(strings(1))
                        pt.z = Double.Parse(strings(2))
                       Dim p As Point
    End Sub
End Module
gives as a result:
in the info window:
264.560
-259.448
-18.276
error message:
System.FormatException: Input string was not in a correct format.
at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Double.Parse(String s)
at Test.Main() in C:\Users\kkukely\AppData\Local\Temp\NXJournals3400\journal.vb:line 23
What??
the 23th row is:
kukelyk
What language/regional settings is your computer set to use?
In win xp this can be found in the control panel under "Regional and Language options", I'd guess it is in a similar location for more recent versions of windows as well.
Really, the problem was in this "Regional and Language options". When I set it to en-US, the Double.Parse runs correctly.
kukelyk
Other problem: it is possible to create points in WCS instead of absolute?
kukelyk
Other problem: is it possible to create points in WCS instead of absolute?
kukelyk
This version should work regardless of your regional setting and it will output the lines relative to the WCS.
Code:
[COLOR=blue]Imports[/color] NXOpen.UF
	Dim ufs [COLOR=blue]As[/color] UFSession [COLOR=blue]=[/color] UFSession.GetUFSession
	Sub Main()
		Try
			Dim openFileDialog1 [COLOR=blue]As[/color] [COLOR=blue]New[/color] OpenFileDialog()
			If openFileDialog1.ShowDialog() [COLOR=blue]=[/color] DialogResult.OK [COLOR=blue]Then[/color]
				Dim theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
				Dim workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
				Dim sr [COLOR=blue]As[/color] StreamReader [COLOR=blue]=[/color] [COLOR=blue]New[/color] StreamReader(openFileDialog1.FileName)
				Dim line [COLOR=blue]As[/color] [COLOR=blue]String[/color]
				Dim startPoint [COLOR=blue]As[/color] Point3d  [COLOR=blue]=[/color] [COLOR=blue]nothing[/color]
				Dim endPoint [COLOR=blue]As[/color] Point3d
				Dim i [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] 0
				Dim USculture [COLOR=blue]As[/color] system.globalization.CultureInfo [COLOR=blue]=[/color] [COLOR=blue]New[/color] System.Globalization.CultureInfo("en-US")
				Try
					While [COLOR=blue]Not[/color] line [COLOR=blue]Is[/color] [COLOR=blue]Nothing[/color]
						Dim delim [COLOR=blue]As[/color] Char() [COLOR=blue]=[/color] {","c}
						Dim strings [COLOR=blue]As[/color] String() [COLOR=blue]=[/color] line.Split(delim)
						endPoint.x [COLOR=blue]=[/color] Double.Parse(strings(0), USculture)
						endPoint.y [COLOR=blue]=[/color] Double.Parse(strings(1), USCulture)
						endPoint.z [COLOR=blue]=[/color] Double.Parse(strings(2), USCulture)
						endPoint [COLOR=blue]=[/color] Abs2WCS(endPoint)
						If firstPass [COLOR=blue]Then[/color]
						Else
				Finally
					sr.Close()
		Catch E [COLOR=blue]As[/color] Exception
[COLOR=green]'&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&[/color]
[COLOR=green]'Date:  11/18/2010[/color]
[COLOR=green]'Subject:  Sample NX Open .NET Visual Basic routine : map point from absolute to wcs[/color]
[COLOR=green]'[/color]
[COLOR=green]'Note:  GTAC provides programming examples for illustration only, and[/color]
[COLOR=green]'assumes that you are familiar with the programming language being[/color]
[COLOR=green]'demonstrated and the tools used to create and debug procedures.  GTAC[/color]
[COLOR=green]'support professionals can help explain the functionality of a particular[/color]
[COLOR=green]'procedure, but we will not modify these examples to provide added[/color]
[COLOR=green]'functionality or construct procedures to meet your specific needs.[/color]
	Function Abs2WCS(ByVal inPt [COLOR=blue]As[/color] Point3d) [COLOR=blue]As[/color] Point3d
		Dim pt1(2), pt2(2) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
		pt1(0) [COLOR=blue]=[/color] inPt.X
		pt1(1) [COLOR=blue]=[/color] inPt.Y
		pt1(2) [COLOR=blue]=[/color] inPt.Z
		ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_COORDS, pt1, _
			UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt2)
		Abs2WCS.X [COLOR=blue]=[/color] pt2(0)
		Abs2WCS.Y [COLOR=blue]=[/color] pt2(1)
		Abs2WCS.Z [COLOR=blue]=[/color] pt2(2)
	Public [COLOR=blue]Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
