Import scaled dxf file 1
cubalibre000
1,070
I've a dxf file that after imported into drawing view, the dimension are scaled.
For example, the orginal drafting has the view scaled 1:1.5 with dimension like 15.
After importing, dimensions like 15 mm become 10 mm.
Idea to resolve ?
Attached dxf file.
Thank you...
Using NX 8 and PDM RuleDesigner
 http://files.engineering.com/getfile.aspx?folder=8f7c22ff-6f01-4690-b89a-ff2552e5fd39&file=dxf.zip
After importing rescale in NX or Prior to importing rescale (1:1) in autocad or other CAD tool.
If you are looking for a rescaling during import, NX can't do that out of the box...( not without custom programming being written )
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Hi Ronald,
scaling the dxf before to import resolve the problem.
Thank you...
