I posted this in the General Engineering program section but have had no luck there. Hope I can get some responses here.
In the Masonry Wall design portion of Enercalc v5.8, what does "parapet height" refer to? The definition provided in Enercalc Help is, "This portion of the wall extends above the Clear Span Height and will apply a concentrated moment due to wind or seismic loads to the top of the wall. Vertical load due to the parapet weight is also included."
What is the parapet wall? Is it part of the masonry wall, and must it be constructed of masonry?
If I just have a stud wall above my masonry wall, is that considered a "parapet wall"? I am thinking that it does not, but I hope someone can verify that.
Thanks for all your responses.
