Dear Floor,
Here in our asset we have Heat Recovery Steam Generator (HRSG) which is 11 years old.
This HRSG utilize flue gas from Gas Turbine to make steam. Feed water comes in to the HRSG thru 6" pipe and exit as steam thru the same size pipe.
Steam pressure is about 740 psig and the temperature is about 540 F.
Currently, we want to conduct hydrotest. what code & standard that appropriate for this test?
Should Asme Sec.1 Para 99 be the match reference for that?
Are there any code & standards more appropriate for this case?
Kindly need your advice..
Thank You
Best Regards,
Andrenov
Thank You
Best Regards,
Andrenov
