Gov45
Automotive
- May 8, 2024
- 14
Hello all
I have a case in ABAQUS calculation where I applied the load on a bracket (bracket is attached to a frame, and bracket and frame are welded together), there is plastic deformation after loading on the frame. After unloading, the plastic strains are increasing on the frame. But as per theory plastic strains after unloading should be same as plastic strains after loading.
Elements used in ABAQUS --> shell elements (S4R)
loading --> max plastic strain 0.009
unloading --> mas=x plastic strains 0.014
Does this have to do anything with the elements?
