Sewing_Engineer
- Mar 1, 2019
- 4
I recently had a problem with our machines shafts where the vibration increases after heat treating our shafts. The initial test was done with a 1040 steel shaft that was not heat treated for the first prototype and had a hardened chrome plating. The production sample Shaft was done with a 1040 steel shaft that was heat treated to 700HV and had a black oxide finish the shaft was designed to only be heat treated 500HV but I thought it wouldn't be a problem with having the material harder then specified but looks like it is but I still want to figure out what is going on. After measuring the shafts total runout they are both with in spec. The only part changed in the machines was the shafts all the same parts were used and when running the machines overall machine vibrations increased. All of my shaft design calculations I did show there will be no problem with the shaft deflecting in any significant amount considering the loads on the shaft are relatively small. With increasing the shaft hardness I assumed their would be little change in the vibration since heat treating has only a marginal affect on 1040 steel modulus of elasticity.
I am wondering if anyone can help me with this problem I have been debating three questions I think could cause this;
1. How the harmonic speed of a shaft will be affected in changing just the material hardness.
2. If the softer steel would have a higher dampening value even though the modulus of elasticity doesn't change much and could be absorbing some of the shock load.
3. If the hardened steel center of mass could be off slightly with having the shaft so hard (I don't think this is very likely or could be causing a significant problem).
