Index of a value in an array
shmmeee
Computer
Oct 21, 2005
1
I'm very new to Mathcad (12), I'm trying to find the index that a particular value appears at in an array. Even better I need to know what index of the element with the highest value is.
I hope that makes sense, a quick example just in case:
say the array = (0,3,9,5,2)
I want a function to return 2 (the index of 9).
Thanks in advance,
Iain
shmmeee,
as long as you have an array, (a matrix with 1 row & 5 cols) as you describe in your post, cols(array) should return 5. The function match(array) should return 2.
If you start with a vector (with 5 rows & 1 col) then use rows(vector) to get 5. match(vector) will return 2.
regards,
chichuck
Match is the correct function, however the correct format is:
match(max(array),array)
This will return a vector containing the index of the maximum value in array.
Peter
You may find in your manual or in the software, sample problems that may help you with this task. For example, go to:
- Resource Center
- Quicksheet References
- Vector and Matrices
- Locating All Elements in an Array That Match a Condition.
Unfortunately, this particular example may not be for beginners. However, this may give you an idea what is require to solve this type of problem.
Good luck.
